610 dial part
All, I'm on the final stretch of my 610 restoration and have a dial  question.  My dial is in relatively good shape but I'm missing the black part that's shown below.  Has anyone made one or is it even necessary?  I suspect it is designed to stay stationary while the dial moves.
Keith
Here are some more pictures of the broken black part of the dial scale.  I'm not sure if I should fabricate a new one or just leave it off.
Keith
I have a 610 and don't think I have ever seen one of those. At least my radio doesn't have one. Looks like it might be some sort of light shield to prevent light from leaking from around the tuning knob.
Certainly does not appear to be a critical part as I have never missed having one.
Thanks Mondial, I too was thinking it might be a light shield. If no one else has one then it must not be important.
Keith
I've seen them before in 620 and 630 models, and the bare space *might* show in the escutcheon if the black piece isn't there. I do not remember as the only 1936 Philcos I own now are the early and late 116B sets, and I do not believe they have a plastic piece like that.
If it doesn't show, no need to worry about it.
Edit: I have to clarify - I forgot my 630 chassis in a 610T cabinet. Icon_redface As I recall, it does not have that piece.
 My 620 doesn't have thee black piece neither,,,,
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
