Philco Knob & button cleaning
I was wondering how everyone cleans their knobs & buttons.
I was thinking maybe an Orange cleaner ?? Looking for simple/ easy.
I used a plastic polish.
I use GoJo and a toothbrush to get the first layer of grunge off then if there is still stuff in the small indentations I'll use some dental tools to do a little scraping and more brushing.  I've heard of folks using an ultrasound bath....but I don't have one of those.  When they are clean I might use some novus to polish them up and then buff them.  How easy and quick depends on how dirty and grungy they were to start with.
For light cleaning (finger grunge and the like), hot water and a denture cleaning tablet like Polident or Efferdent works very well. For heavier dirt and even some kinds of paint splatters, straight ammonia can't be beat. But only use ammonia on bakelite…it can actually melt some kinds of plastics.
Mike Koste
Gobs of Knobs
Zucksville, PA
they are mainly covered in white (Moldy?) stuff. I did dish soap and Murphys Oil soap with a toothbrush ....got some of it.
I let them soak after a liberal spray of furniture polish like Pledge.  Then a soft toothbrush and a soft cloth will get them clean and polished in one step.
I soak mine in Tide, then scrub with a brush. Dry and polish with Plastx.
Eric
The Villages, FL
Eric, do you mean straight Tide, or Tide mixed with water?
Straight. 15 minutes does it.
Eric
The Villages, FL
Very interesting...
I would like to thank everyone who posted. This is good information. Icon_thumbup
That white (moldy?) stuff is likely caused by outgassing of the material. You can clean it off but it will eventually return. I don't thinik anyone has figured out a way to eliminate it yet.
I also soak mine but in hot water and Dawn followed by scrubbing with a brush and finally steel wool.  The steel wool takes off the top oxidized layers. Then I polish the knobs on my buffing wheel using tripoli polishing compound. Just be careful not to apply too much pressure as the friction can actually melt some plastics.  Lastly I apply carnauba wax for protection.
Steve D
For knobs in really bad shape, I basically do what Steve does except I start with the fine wire wheel on my grinder. It can get into the cracks and is fast. Any of this rough treatment requires polishing afterwards. If you use this technique, move quickly. Bakelite is very tough, but if you put too much pressure or stay too long you can burn it.
I've always used Scrubbing Bubbles Mega Shower Foamer. Just put them in the laundry tub. Spray very well. Come back in 15 minutes and rinse in hot water. No fuss. Super clean. Here is a pic from the 37-116 I'm working on. I didn't even pre-clean them, they were super dirty. I'm going to give them a quick coat of gloss lacquer.
Tony
.... very artistic!! Icon_lol
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1142 online users. [Complete List]
» 1 Member(s) | 1141 Guest(s)
