Just purshased 116 tombstone and 91b
Threads: 147
City: Dallas, TX
Congratulations! (Oh, since these are cabinet questions, I moved this thread to Philco Cabinet Restoration.)
(03-22-2015, 11:24 AM)Fred Taylor Wrote: Correct toner for 116 tombstone would be what ? Which v pattern cloth is best for 116 tombstone, radio daze or Richman designs ? Im guessing extra dark walnut around the front face molding and the rest medium walnut for 116 ? Semi gloss or satin ?
Whoa, let's take things one at a time...
Correct toner: Extra Dark Walnut Ultra Classic (dye) toner on the top, sides, and the top, side, and bottom trim surrounding the front panel. This will allow some of the grain to show on the top and sides. Medium Walnut on the front panel itself.
Chevron (V) cloth to use? Richmond Designs.
Semi-gloss or satin? Neither. The original final finish was gloss. If you really don't like high gloss then use semi-gloss, but I would definitely not recommend satin.
Threads: 147
City: Dallas, TX
Thanks Ron, how do you think i did on price? Pretty fair
To me, the 116B price was a bit on the high side, given its condition, but still not out of reason.
Regarding the 91B, well, that seems to be about the going rate for those.
Threads: 147
City: Dallas, TX
(03-22-2015, 01:08 PM)Ron Ramirez Wrote: To me, the 116B price was a bit on the high side, given its condition, but still not out of reason.
Thanks Ron
Threads: 112
City: Medford OR (OR what?)
Ron is right about the gloss, BUT you have to rub it out too. Otherwise it is too reflective. And don't forget the grain filler or you might as well paint it satin.
Russ is absolutely right on this.  Gloss lacquer that isn't rubbed out will end up looking a lot like polyurethane.
Threads: 147
City: Dallas, TX
(03-22-2015, 09:49 PM)Ron Ramirez Wrote: Russ is absolutely right on this. Gloss lacquer that isn't rubbed out will end up looking a lot like polyurethane. Yes I can relate to that, high gloss lacquer is about 90% gloss level until in is wet sanded and buffed, then it will be at 100% gloss and as smooth as glass, is that what should be done on 116?, piano finish. I will grain fill , stain and tone , then apply clear sanding sealer which will then be sanded lightly then I will clear it using Mohawk clear instrument lacquer 4 - 5 coats , which is very durable , wet sand with 1200 grit then then polish . 10/4 will do .Thanks
Well, finding a short is easy.
Like I said, disconnect the transformer's secondary windings and see if it persists.
If...morzh — 09:48 PM |
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM |
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM |
Rogers Majestic R-646
Kinda weird to see both open
Nothing weird if you remember that this radio is about 100 years old :)Vlad95 — 07:49 PM |
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM |
Thanks Morzh
Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM |
Well...pull out every single load of the transformer. For every winding.
Unsolder if needed.
Then re-do your dim bulb....morzh — 07:02 PM |
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM |
Vlad;
I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM |
Thanks RpdB
I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM |
