philco 40-135 Static problem
Good morning,
 I have a Philco 40-135    http://www.nostalgiaair.org/PagesByModel...013328.pdf
That I have recapped, replaced the output transformer replaced the deteriorated wiring checked and replaced out of spec resistors , tubes check good and have even replaced them one a a time to no improvement, looked for bad solder joints and things touching that shouldn't and cleaned and lubed the switch.
   I get a lot of static between the stronger stations, they come in great but the more distant ones have some static. It doesn't seem to matter how long I leave it on I also have a 40-140 that plays great. Should I start looking at the Mica Caps? Not sure where to go at this point. Thanks
Eric
Do both sets have large loop anttenas? Are both table or floor models???
(04-05-2015, 11:28 AM)Radioroslyn Wrote:  Do both sets have large loop anttenas? Are both table or floor models???
Both are table sets and both have loop ant's
Went back over the print and chassis and found 3 resistors 2 of which looked like small caps they were #20, 29,and 30 all were over 40% seems to be much better. I'm going to put it back in the cabinet and give a go.
Thanks Eric
No go, the static seems to come and go to varying degrees, I have looked for bad solder joints and what ever I can think of just when I think I have it and put it in the cabinet it starts again. The static reminds me of what you get on AM when thunder storms are in the area ( there aren't any today here).
I think your best bet is to use a signal tracer going from control grid (input of stage) to plate (output of stage). This will help you determine where the noise coming form. If it was 20yrs newer I'd say it's a bad cap in the Ktran IF transformer.
Have you cleaned the tube sockets? Take a real close look at the tuner for dirt or dust balls down deep, I like to use a flashlight and a hand lens. Good luck David
..and I would not totally rule out "silver-mica disease" either in the IF cans.
And related to that, although a long shot, might be dirty micas sheets in the tuning gang trimmers too.
Chuck
(04-05-2015, 08:13 PM)David Wrote:  Have you cleaned the tube sockets? Take a real close look at the tuner for dirt or dust balls down deep, I like to use a flashlight and a hand lens. Good luck David
I have cleaned the tube pins knowing that locktals can have a problem with corrosion but you can usually hear the difference when you wiggle each tube with the set on. On the Tuner I have cleaned and checked the plates and at the shaft making sure there is no trash bridging the segments, As a side note I have one of those magnifier visor, best thing I ever bought leaves your hands free!
May have found the problem it is the trimmer on the tuner will run it for a few days to see it that is what it is.
Philco 91 Restore Code ??
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
There are currently 3180 online users. [Complete List]
» 3 Member(s) | 3177 Guest(s)
