38-12 power transformer
(04-21-2015, 03:50 PM)morzh Wrote:  Ron
Simple question: if you power WITHOUT rect tube, does it still smoke?
If yes,
If you fully disconnect all your xfmr outputs from wherever they go (filaments etc), and then power, does it still smoke?
No it does not smoke nor get hot without rect tube.
Well, there is your answer: if your transformer does not smoke without rect tube, it is either the tube OR what is after the tube thAt smokes it. Start measuring your load.
Measure Ohms from 84 tube pin 4 (K) to chassis.
Thanks... I hope to work on it tonight...
First Radio restoration
There are currently 1382 online users. [Complete List]
» 1 Member(s) | 1381 Guest(s)
