TWO 16b tombstones/ FINISHED!
Threads: 147
City: Dallas, TX
Threads: 22
City: Waxahachie, TX
Threads: 147
City: Dallas, TX
Agree with Crist - looks good  Probably the next best thing to plating, color-wise.
However, is this paint conductive?
Threads: 147
City: Dallas, TX
The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use
(This post was last modified: 06-08-2015, 07:26 PM by Fred Taylor.)
Threads: 22
Thanks Fred. I'm going to get some of the stuff. The shields look great!
Crist
Threads: 26
City: Hayward, California
(06-08-2015, 07:25 PM)Fred Taylor Wrote: The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use
I'm pretty sure that's why you want conductive paint, so it will be grounded. Otherwise if it's not conductive it wont make electrical contact, unless you scrape off the paint at any points of contact.
(This post was last modified: 06-08-2015, 11:27 PM by Warren.)
Threads: 147
City: Dallas, TX
(06-08-2015, 11:26 PM)Warren Wrote: (06-08-2015, 07:25 PM)Fred Taylor Wrote: The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use
I'm pretty sure that's why you want conductive paint, so it will be grounded. Otherwise if it's not conductive it wont make electrical contact, unless you scrape off the paint at any points of contact. That's what I did was remove some paint on bottom edge of shield, now I have a good ground
Threads: 147
City: Dallas, TX
Threads: 22
Well done Fred!
Crist
Threads: 574
Looking good!
Threads: 337
City: lawrenceville nj
Threads: 574
The paint does not matter fir the shields as long ss you leave the internal base part bare so it connects to the chassis, the rest you can cover with latex based for all I care as long as you like it.
Threads: 147
City: Dallas, TX
(06-12-2015, 12:25 PM)morzh Wrote: The paint does not matter fir the shields as long ss you leave the internal base part bare so it connects to the chassis, the rest you can cover with latex based for all I care as long as you like it.
I mentioned that already and you are right, as long there are grounded good.
Threads: 40
City: McPherson, KS
Those sure are purty radios!
A minor point: I thought the knobs on the earlier and later versions were different.
So far still no broadcast, I am posting pictures of #14 Oscillator and also a resistor #27 which connects to an XXL tube...osanders0311 — 04:02 PM |
I believe there is that document, and I think we might have it in the Library.morzh — 03:29 PM |
Ok MrFixr55,
I have tried the DeoxIT D5 on the band switch and even though it has relieved the tension I felt when turn...osanders0311 — 11:11 AM |
Is there a reference somewhere where you can punch in Philco part numbers and see what models those parts were used in?Jim Dutridge — 10:17 AM |
Hi OSanders,
Look carefully at the band switch. Turn it slowly and "wiggle" it around the desired band. ...MrFixr55 — 12:33 AM |
5U4 vs 5Z4 tubes
I think that RCA and GE introduced metal tubes in the USA in 1936. I don't know if they were being made by RCA, GE or b...MrFixr55 — 11:20 PM |
Vlad95,
Thank you for the stringing guides and wow there are so manyosanders0311 — 06:01 PM |
5U4 vs 5Z4 tubes
A pre war Hallicrafters, and an early one too, very nice! 1936 is pretty early for metal tubes too, which would explain ...Arran — 05:58 PM |
Thanks Rod,
"When you hear the background hiss and no station it usually indicates that the oscillator quit" ...osanders0311 — 05:52 PM |
RodB
:beerchug:Vlad95 — 10:22 AM |
There are currently 980 online users. [Complete List] » 2 Member(s) | 978 Guest(s)
