Fun With Laser Cutters
I recently came across a company called Ponoko that will laser cut a design of your choice into a large number of materials.
As an experiment I decided to create a reproduction grille cloth backing cardboard for my 16B 'shouldered' tombstone since the original one was pretty shot (looks better than it is in the photo). Icon_smile
Here are the steps I took:
  1. scanned the original backing cardboard and cleaned it up in Photoshop
  2. opened the image file in Illustrator and used the 'Image Trace' feature to turn into into vector art
  3. simplified jagged edges and other imperfections (mostly to reduce cost since laser time = money)
  4. colored edges based on what I wanted Ponoko's lasers to do (blue = cut, red = engrave stroke, black = engrave area)
  5. created an account on Ponoko (they currently allow you to make your first product for free - up to $20)
  6. uploaded the Illustrator EPS file
  7. selected material (boring old corrugated cardboard)
  8. placed the order
Here is what arrived in the mail:
They send you the full piece of material you used - each side covered with white stick-on paper (looks like to protect the material while cutting).
Peel off the paper and...voila!
Cutting edge technology used to restore a 1935 radio.  Icon_lol
If you'd like to use the design for yourself, here it is (public domain - costs is just materials and shipping):
http://www.ponoko.com/design-your-own/pr...king-12624
I've attached the original EPS file too in case you want to modify it.
Great job and good resource to know about!!
If you like laser cutters check out this video. I want one!!!! David
[Video: https://www.youtube.com/watch?v=iVrJUbeuG44]
Pretty cool, nice to know that is available.
(07-22-2015, 06:53 PM)David Wrote:  If you like laser cutters check out this video. I want one!!!! David    https://www.youtube.com/watch?v=iVrJUbeuG44
That thing is amazing! My favorite is the ping pong ball.
Part II
This time a new backer for my 16B 'Peak Top' Tombstone (the later version). The old backer was disintegrating so I decided to scan it in and go the laser cutter route again.
Rather than cardboard, this time I selected hardboard since the thickness of 0.118" is a close match for the original.
The design is available at Ponoko. I also attached the EPS file here in case you want to modify it.
It cost $30 total ($6 material, $14.80 laser cutting, $9.50 shipping). Yeah, not exactly cheap. But maybe it makes up for it in cool factor? Icon_smile Anyway, here was what Ponoko sent back:
[Image: http://i1072.photobucket.com/albums/w374...4m4d9j.jpg]
[Image: http://i1072.photobucket.com/albums/w374...u5eftx.jpg]
[Image: http://i1072.photobucket.com/albums/w374...7oilpa.jpg]
And here it is installed:
[Image: http://i1072.photobucket.com/albums/w374...i4xjfx.jpg]
[Image: http://i1072.photobucket.com/albums/w374...gn1fpb.jpg]
The cabinet still needs to be refinished, but I think having the right grille cloth installed is a big improvement!
Why have I never seen this?
Me
This thread or the radio? Icon_smile
That's pretty slick, you did a great job.  You mention using Illustrator, is that an Adobe program?
Yes - Illustrator is for working with 'vector' line art - as opposed to Photoshop which is primarily for pixel based 'bitmap' formats. There is some overlap and each program complements the other.
In this case I scanned the old backer into Photoshop first and cleaned up any imperfections in the scan (dust, tears in the original backer). The I imported that into Illustrator and used the 'Image Trace' feature to make the conversion to vector art.
Ponoko accepts a number of different vector file formats.
http://www.ponoko.com/make-and-sell/design-it-yourself
Doesn't Mark Palmquist do laser cutting?
Nathan,
   That's really excellent. Thanks for sharing.
                                     Henry
Philco 91 Restore Code ??
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
There are currently 5549 online users. [Complete List]
» 1 Member(s) | 5548 Guest(s)
