37-610 IF Cans
Hi all! I've been doing a ground up restoration on a 37-610 tombstone and, despite loads of pictures and supporting documentation, I've encountered several gray areas. I have a code 121 or 122 chassis.  Can't really tell which, as the markings are long gone, but the rectifier tube sits on top of the transformer, so I think this is right. I also purchased a scrap chassis from Playthings in order to salvage some missing parts. This too was supposed to be the same code as mine, but there are many differences. Anyway I took tons of photos of the original chassis and then stripped it bare. Each part was then cleaned, restored or replaced. Now as I'm putting it all back together, I find that the IF cans aren't matching up with the schematic as far as their resistance values. It appears that their placement in the circuit should be swapped. Originally the 1st IF can was up front and had two small black leads along with the four coil leads, but the other can's values are almost exactly what the schematic calls for. Should I go against the original assembly and follow the schematic instead? And where do those two small black leads connect?  Unfortunately, they didn't show up in my pictures. The salvage chassis' IF cans turned out to be totally different. Their values don't match with the my Rider's schematic and they each have internally mounted resistors. There are other issues, but I'd appreciate some feedback to help me get through this one.  I can provide pictures if asked.  Thanks in advance.
No suggestions? Surely someone out there has run across this situation.
Welcome to the Phorum!
You might find some documented changes in the file changes.zip.  Not all changes were documented.  I don't have a 37-610 though.  Nice work!!
(09-07-2015, 10:36 PM)klondike98 Wrote:  Welcome to the Phorum!
Thanks klondike98!  I need to complete the wiring, but hit a wall regarding these If cans.  Also thanks for the link.  Unfortunately, there was no reference to this issue.  I guess I'll go ahead and wire them in, then swap them to see which performs better.
I would put it back the way I found it, but others may gave other thoughts.
I recently worked on a 37-640 which had two small wires in the 1st IF can too. THey were not shown in the schematic but are mentioned in the production changes
"The first I.F. Transformer, Part No. 22-2274 has a stabilizing winding which is placed n series with the suppressor grid of the 6K7G I.F. tube"
It's drawn in on this schematic as the squiggle going up to ground.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
