FOMOCO Radio
That's the antenna trimmer screw.  It usually winds up being screwed in clockwise almost all the way for best reception.  Make sure you have a good antenna connection.  The screw is adjusted by finding a weak station around 1400 and adjusting to maximum volume.  Your radio, however, may be on the fritz.
Craig R
(09-14-2015, 02:12 PM)VntgRads Wrote:  That's the antenna trimmer screw.  It usually winds up being screwed in clockwise almost all the way for best reception.  Make sure you have a good antenna connection.  The screw is adjusted by finding a weak station around 1400 and adjusting to maximum volume.  Your radio, however, may be on the fritz.
Craig R
I checked my stereo AM stations (on my old Pioneer SX-828 receiver from the 70s) to find a station around 1400.  Found one at about 1430, but can't get anything on the Ford radio.  Do you repair these?
No, I don't do the electrical but just the mechanical/cosmetic portion.  You might want to hold off until you find the proper '68 radio for your car.
Craig R.
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
