Threads: 113
City: The Villages
I'm at the point where everything I touch turns to s**t!
I've got a simple Airline model 4705 . Just a simple 6 tube AM radio. Replaced all caps. Tubes and resistors checked OK. Alignment done. Everything is fine except I only get one station . It is WGN, 720 from Chicago (about 40 miles away). It comes in on any dial position. ![Icon_eek Icon_eek](https://philcoradio.com/phorum/images/smilies/icon_eek.gif) It is just as strong at 55khz as it is at 1600khz.
Any clues as to where to start?
Thanks guys,
Eric
The Villages, FL
Threads: 72
City: Linn Creek, MO
Sounds like the oscillator is not working. Have you tried placing another radio near it to see if you can pick up the oscillator?
M R Radios C M Tubes
Threads: 113
City: The Villages
Well Steve, I just checked it. The oscillator is working, but now WGN is gone and the only thing I can pick up is my SSTRAN set at 1500khz. This would be a step in the right direction except that it is coming in at about 700khz no matter what I do to the osc trimmer on the tuning cap!
Eric
The Villages, FL
Threads: 72
Eric, when you listen to the oscillator on the other radio and adjust the trimmer, does it move up and down the dial?
City: Sedona, AZ/Placentia/CA
Eric, do you have a signal generator? A very nice piece to have to troubleshoot these problems.
jerry
Threads: 113
City: The Villages
Sure do, Jerry. I was able to do the IF alignment.
Eric
The Villages, FL
Great Eric, now use it to run AM frequencies into the antenna input but please use an Iso trans on the radio. As you know, this has a potentally hot chassis depending on the plug orientation. Steve is much smarter and there is something wrong in the RF/OSC section. See what you find for a "tone" across the AM band.
Jerry
Sorry, Dup. And sorry Eric if I didn't realize and recognize your experience and knowledge. Best, Jerry
(This post was last modified: 09-22-2015, 09:48 PM by jerryhawthorne.)
Threads: 566
Eric, go save Midas
Threads: 54
Schematic linked to is an Air King 4705, not an Airline, or is your set actually an Air King? If so try replacing the 22k Ohm resistor on pin #1 of the 12SA7 tube. The 22K resistor, or R3, may test fine cold, but may not when the set is powered up.
Threads: 113
City: The Villages
Yes Arran, it is an Air King. The 22k ohm resistor is on pin #3 of the 12SA7 tube. It goes from pin #3 to ground. I replaced it. No change, except now it is motor boating.
No big deal. It is time to put it on the punishment shelf ![Icon_thumbdown Icon_thumbdown](https://philcoradio.com/phorum/images/smilies/icon_thumbdown.gif) and go on to something else.
Thanks for your help,
Eric
The Villages, FL
Threads: 415
City: Boston
I think as a kid I wound up on that shelf. I read a story/interview with a guy who worked at Air King, trouble shooter and supervisor on the line and while they did make some decent stuff they did cut some corners. It may be that some manufacturing may not be to spec or done well to begin with. Sometimes taking a break is good, think about it, work on something else for a change.
Good luck.
Threads: 113
City: The Villages
I think we all ended up on that shelf at one time or another ![Icon_wink Icon_wink](https://philcoradio.com/phorum/images/smilies/icon_wink.gif) It's just that if this keeps up it looks like I'm going to need more shelves!
Eric
The Villages, FL
Threads: 92
City: Clayton, NC
This could be the result of an alignment mis-adjusted to an harmonic of the frequency vice the frequency itself. Also, how do you verify that the F is what it should be.
Threads: 92
City: Clayton, NC
What I mean is do you verify the frequency from your sig gen with a frequency counter?
Philco 91 Restore Code ??
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM |
Philco 40-120C Restoration
Hello David,
that is great news about the tubes source being local !
Sounds like you got good start on the radio .
...radiorich — 09:41 AM |
Mike;
I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM |
Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM |
Mike;
I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM |
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM |
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM |
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David David — 09:14 PM |
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM |
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM |
There are currently 4282 online users. [Complete List] » 1 Member(s) | 4281 Guest(s)
