48-460 Loop Antenna Help Needed
The loop antenna on my recently acquired 48-460 "Hippo" radio is missing. Could someone please provide information about how to wind a new loop? A photo would help along with the wire size/type and number of turns in the loop. By looking at the back of the radio, I think the loop is glued to the inside of the case. Any help would be appreciated.
Richard
It is a flat winding, wound on heavy brown paper and was,indeed, glued to the inside of the cabinet originally. Sorry, don't currently have the specs on wire size or number of turns.
That loop arrangement was not one of Philco's best ideas. You might be better off opting for a non-original loop on the back panel. They aren't all that difficult to make and adjust.
I did this once, a long time ago, on an old radio that originally had it's antenna coil glued to the inside circumference of the cabinet, (I could see the glue tracks.) Don't remember if it was a philco or not. The antenna, and a couple of other vital organs were missing.
I cut out a piece of at least one inch thick styrofoam to just a hair larger than the inside of the cabinet. Then I put a wind of filament wrapping tape (sticky side out) around the styrofoam. Then I took some enameled wire from a trashed transformer, probably 24 guage or so and tacked down the starting end where it would be conneceted with a small piece of the same tape.
Then I wound about 15 turns of wire as carefully as I could one row next to the other. The tackiness of the tape held it down fairly well at the end, I left out a few inches, as in the start, so I could hook it up. I then tacked down the end point with yet another small piece of tape.
Before going further, I hooked up the loop, still on it's styrofoam base, to the radio. To my amazement, it played. Of course if it was not possible to align the set properly, I could have tried removing a turn or two, (or adding a couple more,) but I was good to go. (Madman's luck, I'm sure.)
Then I mated another piece of the same tape to the form, this time sticky side down. Voila, a new loop. Removed from the styrofoam form I could "indent" the four corners slightly and try dry fitting into the cabinet. All was well, and I elmer'ed it in place with a few binder clips (yes, those little black gizmos from the office; cheap, comes in different sizes, you have some of 'em if only you could remember where.)
Anyway, that's one way to do it, it's pretty much 100% reversable. I'm all for low cost/no cost/recycle soloutions.
If anyone out there has a picture of an unmolested antenna on this model , please post. Good luck
Here's some pics.
[Image: http://www.sparkbench.com/h5.jpg]
[Image: http://www.sparkbench.com/h6.jpg]
Looks like 13 turns counted at that corner.
-Bill
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2128 online users. [Complete List]
» 2 Member(s) | 2126 Guest(s)
