GE model 60 clock radio Static
I have a 60 also, recently acquired, thanks to Epay. I also have the model just a little newer. Only difference I can see is that is uses 35W4 and 50C5 tubes instead of the 35Z5 and 50L6. Have you found the problem yet? Thoughts on the problem: This radio originally used metal tubes in all but the Rectifier and Audio out. Does it have glass tubes instead and could it be a shielding problem? Can you produce the problem by making interference intentionally? Have you tried using a signal tracer to find the source? A bad "NEW" cap? Bad ground? Intermittent and static problems can be miserable! My 2 cents...
Tim
GE model 60 clock radio Static - by Eric - 10-27-2015, 04:50 PM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 10:13 AM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 07:16 PM
RE: GE model 60 clock radio Static - by David - 11-01-2015, 06:43 PM
RE: GE model 60 clock radio Static - by Eric - 11-03-2015, 08:46 PM
RE: GE model 60 clock radio Static - by David - 11-04-2015, 09:06 AM
RE: GE model 60 clock radio Static - by codefox1 - 11-26-2015, 02:18 PM
RE: GE model 60 clock radio Static - by TV MAN - 12-16-2015, 10:35 AM
RE: GE model 60 clock radio Static - by Arran - 12-17-2015, 05:13 AM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 12:03 PM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 05:30 PM
RE: GE model 60 clock radio Static - by TV MAN - 03-02-2016, 02:41 PM
There are currently 1384 online users. [Complete List]
» 2 Member(s) | 1382 Guest(s)
