03-11-2016, 09:54 PM
Thanks guys - after rewinding the coil and adding 2 turns per Terry's suggestion, my oscillator came to life again. Then I tuned the osc coil then I adjusted the set. It sounds consistent now but there is some static I can't work out. I can either remove all static but much lower signal strength or get a higher strength signal with static, about 1/4 turn backed off of the osc stop.
Also, when I restored it a year back I did clean the pins and tubes. Never did test the tubes though. I always swap bulbs to assess good from bad but probably not the best technique to use. All caps and resistors have now also been replaced.
