37-670 Glowing Beam Indicator Problem
(03-23-2016, 05:50 PM)Mike Wrote:  http://www.philcorepairbench.com/tips/svctip01.htm
Hi. You might read over this info. see if it helps you.
Thanks.  The problem is not with the shadow meter, but rather with the dial illumination and "glowing beam" dial pointer.  I'm thinking that the dial lamp reflector is not positioned correctly, or perhaps the wrong bulb is installed. I'm afraid of bending things without knowing where the parts should be positioned.
37-670 Glowing Beam Indicator Problem - by davemc - 03-23-2016, 05:32 PM
RE: 37-670 Glowing Beam Indicator Problem - by davemc - 03-24-2016, 07:42 AM
