Threads: 22
City: Waxahachie, TX
The rest of my orders came in so I'm tackling the filter E-Caps and the high voltage sections which consist of the HV cage and the HV board underneath the chassis.
I first did the HV Cage then followed by the HV board. I still have to install the HV board. I'll install the HV cage just before I power it up. With it off it makes working on the chassis a lot easier.
[Image: http://i1060.photobucket.com/albums/t458...ufrydq.jpg]
[Image: http://i1060.photobucket.com/albums/t458...j5xjlw.jpg]
[Image: http://i1060.photobucket.com/albums/t458...ipjx1h.jpg]
[Image: http://i1060.photobucket.com/albums/t458...dcvvy1.jpg]
Crist
(This post was last modified: 04-10-2016, 01:22 AM by Crist Rigotti.)
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
| Dale: Modified topic as suggested. It is not for a specific project. I found it in a box of stuff I recently purchased...GRG — 10:34 AM |
That looks a lot like an aircraft connector of some kind ...
That is a MIL-5015 style connector, used in a wide v...DaleHCook — 10:19 AM |
| I would suggest changing the topic from "P45-6365 Universal Transformer" to "45-6365 Universal IFT."...DaleHCook — 10:08 AM |
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
There are currently 2085 online users. [Complete List] » 2 Member(s) | 2083 Guest(s)
