RCA Q-103 tube ?
(05-17-2016, 04:33 PM)Radioroslyn Wrote:  Well You could try tuning the bcb oscillator by monitoring it's signal in a well calibrated receiver. Use C-6 to set the osc signal heard in the well calibrated receiver at 1755kc (1300+455kc) with the dial set at 1300kc on the RCA. Same thing for the low end of the band. Use L-9 to set the osc heard in the well calibrated receiver at 1055kc (600+455kc) with the RCA dial set at 600kc. It's not uncommon to have so interaction between these two adjustment so you may have to adjust these a few times to get it on the nose. If you can't get the osc to tune from 1055 to 1755kc and your bandswitch is good and clean them I'd replace C-8 and C-11.
The other thing that comes to mind is interference from other electrical devices like cell phone/lap top chargers or computers. They use switching mode power supply and generate a lot of rf noise which can be very strong.
Set the radios up like you said the signal was picked up at 1755 and peaked using C6 and 1055 using L9 I would say it is a little better but still need to hook up my garage antenna to really get anything.
RCA Q-103 tube ? - by Eric - 05-06-2016, 03:00 PM
RE: RCA Q-103 tube ? - by Phlogiston - 05-06-2016, 03:35 PM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-07-2016, 12:12 AM
RE: RCA Q-103 tube ? - by Eric - 05-08-2016, 09:42 AM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-08-2016, 07:34 PM
RE: RCA Q-103 tube ? - by Eric - 05-11-2016, 03:35 PM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-11-2016, 04:32 PM
RE: RCA Q-103 tube ? - by Eric - 05-12-2016, 03:20 PM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-12-2016, 03:57 PM
RE: RCA Q-103 tube ? - by Eric - 05-13-2016, 08:58 AM
RE: RCA Q-103 tube ? - by Eric - 05-17-2016, 11:02 AM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-17-2016, 04:33 PM
RE: RCA Q-103 tube ? - by Eric - 05-19-2016, 04:51 PM
RE: RCA Q-103 tube ? - by Eric - 05-18-2016, 07:19 PM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-18-2016, 07:54 PM
RE: RCA Q-103 tube ? - by Eric - 05-19-2016, 10:45 AM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-19-2016, 06:16 PM
RE: RCA Q-103 tube ? - by Eric - 05-20-2016, 11:55 AM
RE: RCA Q-103 tube ? - by Radioroslyn - 05-20-2016, 09:16 PM
