GE 107 loop antenna replacement
The resistance means very little. Inductance is what you need to know. The short answer is to approximate total length of the wire that was used on the original loop. The gauge is not super critical but you don't what to use 10g where it had 30g. Wind a new loop and add 6" extra of wire to your loop. Connect it to your set and adjust the ant trimmer for a sharp peak. If you can't get a peak cut off 1" at a time till you do.
Simple right!!
GE 107 loop antenna replacement - by Tgace459 - 05-28-2016, 11:16 PM
RE: GE 107 loop antenna replacement - by Radioroslyn - 05-29-2016, 12:58 AM
RE: GE 107 loop antenna replacement - by Tgace459 - 06-19-2016, 09:35 PM
RE: GE 107 loop antenna replacement - by Tgace459 - 06-20-2016, 09:32 AM
RE: GE 107 loop antenna replacement - by Tgace459 - 06-20-2016, 12:58 PM
RE: GE 107 loop antenna replacement - by Tgace459 - 06-20-2016, 11:37 PM
