08-27-2016, 08:13 PM
Glad you got it out safely. Speaking only for myself, I use Windex on dial glass. You should be safe on the outside but on the backside, try it in an inconspicuous spot over some of the yellow area to make sure the paint doesn't come off. Just be gentle...use soft white paper towel or a Kleenex.
Good idea with going slow on the recap. If you have a parts list, check them off as you replace them. That way you can double check as you go that you replaced with the proper value and voltage rating.
Not sure which video the reflocking was in...believe there are 11 or 12 videos in the series. Fun to watch, though!
