Model FM-61 Automatic brand fm converter.
So I was able to locate a schematic for this unit, and was able to verify the make shift radio antenna fortunately it was connected in the right spot, I made the correct connections to the antenna on my tester radio found where it tuned into which was right around 870 on my AM unit and surprisingly it works. The only problem I did find is that it goes okay to the bottom end of the scale and picks up all the local stations there, but it doesn't seem to go past around 103.3, so would this be an alignment issue, or a dirty tuner?
RE: Model FM-61 Automatic brand fm converter. - by flatheadjr - 11-04-2016, 09:39 PM
There are currently 1530 online users. [Complete List]
» 4 Member(s) | 1526 Guest(s)
AvatarAvatarAvatarAvatar
