Power transformer in a 12 volt/25 volt radio?
(11-28-2016, 01:04 PM)morzh Wrote:  Charlie
Both transformers you have listed are 25V only. How are  you going to obtain the high V output for the  rectifier?
Well, that was the issue. I think I would have to run TWO transformers: one that supplied HV and 6.3 filament, and another that supplied 25VCT, so I could cover all filament voltages...that is unless I could stumble on the exact transformer that Stewart Warner had made for this set.
I have a Philco 77 chassis that had a burned out HV secondary in the original but the filament secondary. The solution the technician from the 30s used was to bolt in a second power transformer from another Philco to provide the HV for the set and power it from the mains. I have no idea how well it worked. I used the chassis for parts.
That is why I've been thinking about the 6 volt solution.
Charlie in San Antonio
RE: Power transformer in a 12 volt/25 volt radio? - by ccomer1955 - 11-28-2016, 02:32 PM
