Giid leak voltage on Sears 101.557-1 chassis
(11-30-2016, 09:46 PM)Radioroslyn Wrote:  Methinks you mean C-8, possible maybe may alter the cathode voltage a bit. also check R-2.
Yeah, kinda thought that might be the case. Yep, c-8.  Resistors don't use mfds.  Also noticed B+ is about 14 volts low at the rectifier cathode, but plate voltages only about 5 volts low, i.e., 140 reading 135-138.  Possible problem?  Unfortunately don't have any 25z6's to replace it with.  Anyway, will replace c-8 and see what happens.  Thanks, Terry.  Ed
RE: Giid leak voltage on Sears 101.557-1 chassis - by leftwing25 - 12-01-2016, 06:45 PM
