118X electrical overhaul
OK, so the Field Coil is the terminals that are reading 1100, and the OPT is shot. (Verified)
Looking into the speaker, it looks like I'm in for a rebuild, as the inside is in bad shape, with the wires are pulled out from the speaker cone.
I would like to replace the speaker with a PM speaker. As I understand it, I can use the Field coil from the original speaker and not have to mess with resistors and chokes. Then I will replace the OPT with the following OPT https://www.tubesandmore.com/products/tr...15-w-80-ma
(I chose this OPT as it has a wide variety of impedance to choose from depending on the Taps used)
I can even get my B+ from the same side of the Field coil as I can see where its tapped into the original OPT
Then replace the 10.5" speaker.
I may even cut out a new speaker board, and place the original speaker in the void of the cabinet attached to the board. That way I can always revert back if needed.
I took the following info from another post, and I am putting it here for easy reference.
The audio output transformer is Philco Part No. 32-7078.
Secondary impedance = 1.25 ohms
Primary impedance = 5,580 ohms
Primary D.C. resistance of the 32-7078 output transformer is 310 ohms (Philco Service Bulletin 180B)
Any issues with this plan?
118X electrical overhaul - by Davros - 12-29-2016, 10:24 PM
RE: 118X electrical overhaul - by klondike98 - 12-29-2016, 11:54 PM
RE: 118X electrical overhaul - by morzh - 12-30-2016, 12:12 AM
RE: 118X electrical overhaul - by Radioroslyn - 12-30-2016, 02:02 AM
RE: 118X electrical overhaul - by Davros - 12-30-2016, 02:03 PM
RE: 118X electrical overhaul - by morzh - 12-30-2016, 04:40 PM
RE: 118X electrical overhaul - by Davros - 12-30-2016, 07:41 PM
RE: 118X electrical overhaul - by morzh - 12-30-2016, 08:17 PM
RE: 118X electrical overhaul - by Davros - 01-01-2017, 05:09 PM
RE: 118X electrical overhaul - by morzh - 01-01-2017, 05:20 PM
RE: 118X electrical overhaul - by Davros - 01-01-2017, 10:40 PM
RE: 118X electrical overhaul - by morzh - 01-01-2017, 10:49 PM
RE: 118X electrical overhaul - by Radioroslyn - 01-01-2017, 11:10 PM
RE: 118X electrical overhaul - by Davros - 01-02-2017, 07:54 PM
RE: 118X electrical overhaul - by Davros - 01-02-2017, 09:18 PM
RE: 118X electrical overhaul - by Mondial - 01-02-2017, 10:17 PM
RE: 118X electrical overhaul - by morzh - 01-02-2017, 10:17 PM
RE: 118X electrical overhaul - by Davros - 07-17-2017, 05:26 PM
RE: 118X electrical overhaul - by morzh - 07-17-2017, 06:07 PM
There are currently 1983 online users. [Complete List]
» 4 Member(s) | 1979 Guest(s)
AvatarAvatarAvatarAvatar
