03-22-2017, 09:41 PM
Continued!
After drilling holes around the circumference it was still stuck so I started using a larger bit and worked my way out from the center to the edges. Eventually I got it to where I could pull out fairly decent sized chunks using some needle nose pliers and finally had it cleaned out to within about 3/4" of the bottom (or top if you will)
At this point it seemed like I was getting into some of the black tar-like substance similar to what was in the smaller cap. So I resorted to heat. Using a heat gun I warmed it up until it was obvious that the black substance was softening than started digging with a small screwdriver. Finally the remains popped out
Now both cans had that black substance in the bottom so I filled them with lacquer thinner and let them sit a few minutes. Using a screwdriver I swabbed a paper towel around inside them and after two or three repetitions they were both clean.
This is as far as I've gotten. As soon as I find a Dremel attachment with a fairly sharp point I'll cut the get them re-stuffed!
Rich
Rich
