Frayed Wires at Speaker Plug
Thanks Ron and Chuck. I carefully drilled off most rivet head on inside of plug with like a 3/16 bit. With a pliers I was able to lift up what was left of rivet head and then I pushed out by hand with correct size punch. When I reassembled I pushed original rivets back in with slip joint pliers and used a center punch to carefully flare rivet head (what was left of it) back out. The brass is soft so it doesn't take much and I followed Ron's suggestion and was careful with bakelite. Then I put drop of super glue down on head to help secure rivet to bakelite. It's not as strong as original but for my needs it should be ok. Bill
Frayed Wires at Speaker Plug - by Guest - 01-07-2010, 09:59 PM
Re: Frayed Wires at Speaker Plug - by Ron Ramirez - 01-07-2010, 10:55 PM
Re: Frayed Wires at Speaker Plug - by Allen in SB - 01-07-2010, 11:01 PM
Re: Frayed Wires at Speaker Plug - by Guest - 01-08-2010, 01:54 PM
