46-1226 code 125 restoratioin *DONE
#37
final layout of all caps and resistors replaced.
off the filter cap section i could not find in my thousands of resistors a 4.7ohm or a 68ohm that lead up to the volume.
I could have used parallel replacements but these checked out ok so i will roll with what i have in original form.
i replaced the caps inside the bakalite brick shown on the xfrmr primary.
next i gut and replace caps inside my secondary power supply filter caps (metal cans).  the downside is that i only have axial caps,, wishi i had radial ones,, it would work out much safer.
heres a before and after shot
46-1226 code 125 restoratioin *DONE - by jcassity - 03-19-2017, 11:03 AM
RE: 46-1226 code 125 restoratioin - by klondike98 - 03-19-2017, 01:57 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-19-2017, 06:31 PM
RE: 46-1226 code 125 restoratioin - by David - 03-20-2017, 07:52 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 03-20-2017, 10:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 11:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-23-2017, 09:18 PM
RE: 46-1226 code 125 restoratioin - by Arran - 03-24-2017, 12:24 AM
RE: 46-1226 code 125 restoratioin - by morzh - 03-24-2017, 10:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-24-2017, 10:45 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-28-2017, 12:47 PM
RE: 46-1226 code 125 restoratioin - by sam - 03-28-2017, 01:44 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-30-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 01:20 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 01:32 PM
RE: 46-1226 code 125 restoratioin - by David - 03-31-2017, 07:46 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 09:39 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 03:12 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 12:03 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 09:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-04-2017, 10:24 PM
RE: 46-1226 code 125 restoratioin - by Arran - 04-04-2017, 11:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-05-2017, 02:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 10:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 04:33 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-07-2017, 10:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-08-2017, 01:49 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-13-2017, 09:30 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-14-2017, 07:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 10:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 10:42 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-15-2017, 12:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 10:00 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-16-2017, 10:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 10:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-17-2017, 06:36 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-17-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-19-2017, 08:19 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 08:54 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 04:49 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 10:06 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 09:24 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 09:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:56 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:04 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 10:08 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 10:49 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 11:31 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 12:40 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 12:55 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 12:59 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:35 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:00 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 06:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 06:32 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-22-2017, 07:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 10:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-22-2017, 10:22 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-22-2017, 11:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 09:38 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-23-2017, 10:34 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 10:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-24-2017, 08:34 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 03:44 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-25-2017, 06:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 06:12 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-26-2017, 11:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-27-2017, 06:52 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 10:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 06:41 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-28-2017, 09:44 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-28-2017, 10:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 10:49 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 11:17 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 02:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 03:17 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 03:18 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 03:40 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 04:41 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 04:43 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 06:10 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 08:11 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 09:42 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 09:52 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 09:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 12:19 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:12 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 09:27 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-30-2017, 10:20 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 11:56 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 10:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 11:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 11:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:27 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:31 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 09:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:18 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 09:27 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 09:53 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 01:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 02:40 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 02:50 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 03:13 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 03:16 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 04:10 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 04:19 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 07:23 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 07:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-03-2017, 08:58 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-03-2017, 12:23 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-04-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-04-2017, 10:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 07:45 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 09:48 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 10:50 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 10:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-06-2017, 10:51 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-06-2017, 02:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:26 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 11:37 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 09:47 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-07-2017, 11:00 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 06:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 06:49 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 10:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 10:19 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-10-2017, 11:54 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 12:32 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 10:28 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-13-2017, 04:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-15-2017, 08:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:50 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 10:58 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 06:15 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 02:09 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 06:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 07:38 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin *DONE - by sam - 05-22-2017, 10:45 PM
Antenna options - by jcassity - 05-19-2017, 07:04 AM
