crosley model 148 cap question
Thanks again for the help Terry and Greg.
First time I have ever run across the double caps.
If I may ask one more quick question concerning the large wire wound resistor that is dropping its coating all over the place.
It is the one connected between pins 3 and 6 on one of the 58 tubes.
If I put my ohm meter on it I got about 10 meg ohms. Had to scrape some green crud off the leads to get a reading.
I would like to replace it if I knew what value it is. I see the schematics rates the resistors in watts.
I don't want to call it done until I address this.
Should check out the rest of the resistors as well.
murf
crosley model 148 cap question - by murf - 04-19-2017, 09:16 PM
RE: crosley model 148 cap question - by gregb - 04-19-2017, 09:48 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 10:25 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 11:02 PM
RE: crosley model 148 cap question - by gregb - 04-19-2017, 11:09 PM
RE: crosley model 148 cap question - by murf - 04-19-2017, 11:29 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 03:59 PM
RE: crosley model 148 cap question - by gregb - 04-20-2017, 07:00 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 07:24 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 08:45 PM
RE: crosley model 148 cap question - by David - 04-20-2017, 08:56 PM
RE: crosley model 148 cap question - by murf - 04-20-2017, 10:00 PM
