Single wire antenna has stray voltage- solved
On the S 38 there is ac leakage (normal) from B- to chassis ground because of the line filter cap (from the ac line to B-) and cap and it's parallel resistor connected from B- to chassis ground. If you look at the ant circuit the bottom end of the ant coils there connected back to the chassis through a cap which couples some ac to ant connection.
Trade your S 38 in for a set with a power transformer and you won't have these ground and shock issues. This a post war entree level set, for what it is it has a decent design BUT it's still a pig with lipstick.
Now I think I've got it!
There are currently 1860 online users. [Complete List]
» 2 Member(s) | 1858 Guest(s)
