One of the spoils
Tnx Kman!
Tube came in the other day so I unsolder the diode and installed the 117Z6 and no dice... So measured voltage and found that the filament string was at 7.5v, not good. Portables with low volt/low current tubes need to be pretty close to the proper filament voltage . In this case it require 9-9.5v to operate. Ended up adding a 20K@2w in parallel with the 1700 ohm filament dropping resistor giving me 9.1v.
As an aside my line volt here is fairly low @113vac
On the schematic it shows a dial light (used in ac operation only) but this set shows no sign of having one. I wired up a bulb and it does work just have to fashion a mounting bracket.
Now I think I've got it!
One of the spoils - by Radioroslyn - 05-14-2017, 04:48 PM
RE: One of the spoils - by sam - 05-14-2017, 06:33 PM
RE: One of the spoils - by WallaceRoger - 05-14-2017, 08:06 PM
RE: One of the spoils - by sam - 05-14-2017, 08:37 PM
RE: One of the spoils - by Mondial - 05-14-2017, 08:41 PM
RE: One of the spoils - by Radioroslyn - 05-14-2017, 09:29 PM
RE: One of the spoils - by Radioroslyn - 05-18-2017, 07:18 AM
RE: One of the spoils - by OldRestorer - 05-18-2017, 08:22 AM
RE: One of the spoils - by sam - 05-18-2017, 11:34 AM
RE: One of the spoils - by OldRestorer - 05-18-2017, 12:36 PM
RE: One of the spoils - by sam - 05-18-2017, 12:42 PM
RE: One of the spoils - by Radioroslyn - 05-23-2017, 11:07 AM
RE: One of the spoils - by Radioroslyn - 05-23-2017, 11:09 AM
RE: One of the spoils - by sam - 05-23-2017, 11:25 AM
RE: One of the spoils - by Radioroslyn - 05-23-2017, 02:49 PM
RE: One of the spoils - by OldRestorer - 05-23-2017, 04:13 PM
There are currently 1636 online users. [Complete List]
» 1 Member(s) | 1635 Guest(s)
