41-287 No voltage from secondary of transformer
Hello Ron, Thanks for the fast response. To answer your question, I measure 532 vac across the plates of the 84 rectifier tube. The schematic shows 265 vdc across the 12uf ecap. Having replaced it with 22uf I show 360vdc and across the 16uf ecap the schematic indicates 180vdc. With the replacement 22uf ecap item 27A shows neg 56. Also you asked about the Candohm resistor, yes, I removed the entire piece and replaced it with separate 5 w ceramics of 15, 33 and 150 ohms. I also noticed an error when I changed the 12uf ecap - I had the negetive side to ground rather than the center tap of the transformer. So, no sound no smoke just filament and indicator lights. JEP
41-287 No voltage from secondary of transformer - by Guest - 03-08-2010, 04:10 PM
Re: 41-287 No voltage from secondary of transformer - by Guest - 03-09-2010, 02:19 PM
