37-630....middle of the road set?
The 37-116 seems to have one of the acoustical resonators missing, there should be a third one mounted below the speaker, they can be found and are not necessary to make the set play. Overall it does not look too bad, one problem those cabinets sometimes have is the veneer splitting across the grain along the top leading edge, if really bad the side front corners will be split too, this doesn't seem to have that, just the one obvious veneer chip and flaking lacquer. Even if you were not ready to work on it now you could always put it in dry dock for the future, if you decide later that you don't want it a trade for something else is always a possibility.
37-630....middle of the road set? - by dal61 - 10-01-2017, 01:54 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 04:38 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 08:59 PM
RE: 37-630....middle of the road set? - by dal61 - 10-01-2017, 11:30 PM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 07:24 AM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 10:43 PM
RE: 37-630....middle of the road set? - by morzh - 10-02-2017, 10:54 PM
RE: 37-630....middle of the road set? - by dal61 - 10-02-2017, 11:29 PM
RE: 37-630....middle of the road set? - by SteveG - 10-02-2017, 11:40 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 07:34 AM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 12:32 PM
RE: 37-630....middle of the road set? - by morzh - 10-03-2017, 01:17 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 05:03 PM
RE: 37-630....middle of the road set? - by morzh - 10-03-2017, 05:08 PM
RE: 37-630....middle of the road set? - by dal61 - 10-03-2017, 08:20 PM
RE: 37-630....middle of the road set? - by Arran - 10-03-2017, 10:25 PM
RE: 37-630....middle of the road set? - by dal61 - 10-05-2017, 01:15 PM
RE: 37-630....middle of the road set? - by SteveG - 10-05-2017, 03:32 PM
RE: 37-630....middle of the road set? - by dal61 - 10-08-2017, 03:25 PM
RE: 37-630....middle of the road set? - by dal61 - 10-08-2017, 07:24 PM
RE: 37-630....middle of the road set? - by dal61 - 10-09-2017, 10:18 PM
There are currently 1911 online users. [Complete List]
» 1 Member(s) | 1910 Guest(s)
