10-23-2017, 09:04 PM
Hey Tommie,
Setting the buttons are easy. Set band switch to pushbutton. Look into the back of the pb assbly and you'll see two rows of adjusts (trimmer caps). One peaks up the ant the other adj the osc (set what station you'll hear). You'll notice some frequencies stamped into bracket holding the trimmers. It's is the range that the pb associated with the trimmer will tune. Trimmers toward the right side tune the low end of the band the left side the high end. There is a drawing of them of the lower right corner of the schematic.
Push in the second button (1st is the off/on sw) and you should be able set the osc trimmer to hear stations at the low end of the band. You may have to peak up the ant trimmer when adjusting the osc. The next pair of trimmers are for the next button and so on..
Probably a good idea to have the chassis in the cabinet and the loop ant connected.
Now I think I've got it!
