Adding A supply to this B Battery Eliminator
>Found this on AES, will that work?
No not for this. It's a 7815. 78=linear regulator 05= 5v (fixed, nonadjustable).
The LM-317T is an ADJUSTABLE regulator. It has 3 terminals, in, out, and voltage set. You can put up to 37vdc in and adj it down to as low as 1.2vdc. Max current is 1.5a for the T version the K (TO-3 package) will do 3a.
The pot allows you to continuously set your output voltage ANYWHERE from the input voltage (in are case 10v) to 1.2v
You might want to grab a few extras as they are real handy when building lv p/s. I'm not sure how it does it but the output ends up being cleaner (no hum) than the input which may have a little.
On the B supply you could buy a 6-10k power resistor w/an adjustable slider to set the output voltage. Like this one.
Now I think I've got it!
RE: Adding A supply to this B Battery Eliminator - by Radioroslyn - 12-17-2017, 12:12 PM
There are currently 1970 online users. [Complete List]
» 4 Member(s) | 1966 Guest(s)
AvatarAvatarAvatarAvatar
