01-04-2018, 06:50 PM
I'd like to do that with the caps live under load in the circuit so i can do the amp/volts readings then do the math to see were each cap is at compared to its stamped rating.
problem is i dont have an amp clamp solution small enough to wrap around the + lead of each one.
I dont want to desolder and put my meter in series each time.
do you have a solution to get the amp reading on each cap wihout desoldering?
Ive never had to desolder on larger caps because there's always been wiggle room enough for individual wires leading to the larger caps ive messed with in the past.
