05-03-2010, 03:05 PM
Do you know how I can safely remove the center cap on the dial? I'm afraid to put a lot of pressure on it, if it is anything other than a pressure fit. Thought I might be able to find a similar clock spring, if I can get to it. Also need to straighten the dial, but I have seen the write-up on that problem and will be able to correct that problem, once I get the dial off.
