Scott 16 - Restoration Begun
#36
That was, at least an attempt at a better transformer. You could wind it with the primary entirely on the inside (conventional). Or you can do it like it was. Sounds like you only need to rewind the outside section, which, I'll bet, was the same value(s) as the inside section. Either way, you will probably not be able to tell the difference.
Some audio transformers were wound side-by-side attempting to get better response.
Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 12:48 AM
RE: Scott 16 - Restoration Begun - by Brad Winder - 12-28-2017, 02:16 AM
RE: Scott 16 - Restoration Begun - by Eliot Ness - 12-28-2017, 11:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 12:24 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 03:37 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 06:50 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 10:01 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 10:42 PM
RE: Scott 16 - Restoration Begun - by tasar - 02-27-2018, 09:59 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 10:51 AM
RE: Scott 16 - Restoration Begun - by KCMike - 02-27-2018, 11:22 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 11:34 AM
RE: Scott 16 - Restoration Begun - by Arran - 03-02-2018, 02:24 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 03-24-2018, 10:52 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-18-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by morzh - 04-18-2018, 09:54 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-19-2018, 11:48 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 12:10 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 09:55 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 10:21 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 11:03 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 01:15 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 10:36 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 12:30 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 12:39 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 09:25 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:45 AM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:54 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 08:28 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 09:12 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 10:16 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 12:04 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 01:02 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-26-2018, 10:30 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-27-2018, 10:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-27-2018, 10:20 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 10:30 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 11:32 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-22-2018, 02:47 PM
RE: Scott 16 - Restoration Begun - by Brad Winder - 06-22-2018, 04:56 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 05:57 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-23-2018, 12:22 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-23-2018, 01:37 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 07-03-2018, 04:45 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 08:10 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-28-2018, 09:10 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 09:16 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-29-2018, 11:12 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-30-2018, 07:11 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-03-2018, 11:04 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-12-2018, 09:17 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-30-2019, 06:53 PM
RE: Scott 16 - Restoration Begun - by Scott D - 04-25-2020, 07:27 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2020, 12:16 AM
There are currently 1567 online users. [Complete List]
» 1 Member(s) | 1566 Guest(s)
