41-608, re-installing BoL changer
Hi Brian, and welcome.
Is the BOL changer you found a 1941 changer, or a 1942 changer? And if it is a 1941, is it the standard changer (two posts on top) or the De Luxe Inter-Mix changer (three posts on top)?
If it is the standard 1941 changer, I can probably help you. I have a 41-610 from which the BOL changer (the standard type) has been removed. I can photograph the mounting board, furnish measurements of the opening, etc. Just let me know.
The original mounting board was 1 inch plywood. Of course, 1 inch plywood is no longer being made, so you can either use a single 3/4 inch board, or try gluing a 3/4 inch and 1/4 inch board together, then cut the hole for the changer.
If anyone has any comments on this issue, I too would like to hear them as I need to make a new mounting board for a 41-616.
41-608, re-installing BoL changer - by Guest - 06-12-2010, 02:06 PM
Re: 41-608, re-installing BoL changer - by Ron Ramirez - 06-12-2010, 05:25 PM
Re: 41-608, re-installing BoL changer - by Guest - 06-12-2010, 07:16 PM
Re: 41-608, re-installing BoL changer - by Guest - 06-14-2010, 12:18 PM
There are currently 1864 online users. [Complete List]
» 1 Member(s) | 1863 Guest(s)
