BATTERY ACID REPAIR
Hello everyone.  Recently I became the owner of a beautiful Freed - Eisemann nr-10 in a full cabinet with battery storage area.  Photos are in the July Finds and Losses section of the Phorum.  The side panel of the cabinet was exposed to battery acid and has a fist-sized area of discoloration and wood rot as a result from the interior out through the external finish.  Any ideas as to how I can repair this?  The panel only seems to be 1/4 inch plywood.  My initial idea was to remove the damaged area, refill the area with a new section of wood or filler, then re-veneer the exterior and refinish the entire cabinet.  I'm hoping you guru's have a better idea.  Thanks in advance, Gary
BATTERY ACID REPAIR - by GarySP - 07-21-2018, 12:03 PM
RE: BATTERY ACID REPAIR - by Phlogiston - 07-21-2018, 12:36 PM
RE: BATTERY ACID REPAIR - by Arran - 07-22-2018, 08:32 AM
