Restoring a 46-1209
Based on the schematic, the speaker's field coil is part of the power supply which is typical. Shows on drawing to be 650 ohms. You could use a 500 ohm 10 watt resistor to get the B+ voltage up for a temporary test. But will need to find permanent speaker and wire that in too. Any size less than 6" should work as a test. Not sure about your question is about needing an amp, should be OK with push-pull output already there. Richard
Restoring a 46-1209 - by Guest - 08-17-2010, 06:47 PM
Re: Restoring a 46-1209 - by rghines1 - 08-18-2010, 08:42 AM
Re: Restoring a 46-1209 - by Ron Ramirez - 08-18-2010, 06:51 PM
Re: Restoring a 46-1209 - by marcapra - 09-25-2010, 04:13 PM
There are currently 1726 online users. [Complete List]
» 1 Member(s) | 1725 Guest(s)
