41-616 restoration
Since no one has piped in on this I will...
I'm not 100% certain but I believe you can use a nonpolar cap for that 16uF. Antique electronics sells a solen film nonpolar cap @ 22uF that should work.
I measure the resistors in sets I'm restoring and replace those that are >20% off. Some folks replace them all while they are under the chassis. For the most part 1/2 watt resistors will do the trick but as Phlogiston mentioned in another thread recently, 2 watt resistors are readily available and can easily be used. The size of the original resistors gives you a hint at the wattage. Except for candohm and wirewound they would not usually be larger than 2 watts.
41-616 restoration - by 78zenithtv - 10-20-2017, 01:42 AM
RE: 41-616 restoration - by 78zenithtv - 10-20-2017, 09:19 AM
RE: 41-616 restoration - by Ron Ramirez - 10-21-2017, 07:10 AM
RE: 41-616 restoration - by klondike98 - 10-21-2017, 02:00 PM
RE: 41-616 restoration - by 78zenithtv - 10-21-2017, 02:20 PM
RE: 41-616 restoration - by Ron Ramirez - 10-25-2017, 06:10 AM
RE: 41-616 restoration - by 78zenithtv - 10-24-2018, 10:06 AM
RE: 41-616 restoration - by Arran - 10-24-2018, 09:20 PM
RE: 41-616 restoration - by 78zenithtv - 10-28-2018, 05:01 PM
RE: 41-616 restoration - by 78zenithtv - 10-28-2018, 05:02 PM
RE: 41-616 restoration - by klondike98 - 10-29-2018, 10:41 AM
RE: 41-616 restoration - by 78zenithtv - 10-29-2018, 12:58 PM
RE: 41-616 restoration - by Steve Davis - 10-29-2018, 02:23 PM
RE: 41-616 restoration - by klondike98 - 10-29-2018, 04:21 PM
41-616 restoration - by klondike98 - 10-20-2017, 08:24 AM
There are currently 2290 online users. [Complete List]
» 1 Member(s) | 2289 Guest(s)
