12-21-2018, 04:30 PM
Thank you very much for this information, Chas ! It will be very helpful. Mine still had a badly worn label on the bottom, but I had to remove it to get continuity with thew wiring again. The connectors had lost continuity with the binding posts through electrolytic action from the field coil side. I had to remove the label to get at the screws beneath it that held the binding posts and wires to them. Sad. If you ar anyone else has a picture of the label, please post it, and I will scan it and glue it back on the bottom once I finish restoring the speaker. Right now I have to bump out some dents in the field coil cover. I removed it easily enough, it is held in place by a big brass or bronze snap ring.
