12-26-2018, 06:26 PM
7. Not quite sure what diagram you are using as I couldn't find any that had a motor associated w/it. Would think it's a 16B code 121 (table radio) I'm pretty sure this http://www.nostalgiaair.org/Resources/139/M0013139.htm would be the suitable diagram for your set.
This may show most of the connections but check the upper output tube - it shows no DC supply going to the screen. I believe it is triode-connected to the plate because the voltage chart shows the same voltage for screen and plate of each output tube.
