Heathkit GD-1B
Hmmm, Yes I thought of that.
I've been trying to just check the circuit at this point without letting out any magic smoke.
I have taken the line voltage up to 80 VAC which gives 96 or so on pin1.
These measurements are static as I removed the tube.
The other leg of the 95 VDC supply shows a reading of 10 VDC or so, so those resistors have an effect on the voltage.
I just now went back and re-measured with the tube installed.
I took it up to maybe 75 VDC, nothing.
I tried 80 VAC on the line again, and THIS time voltage on pin 1 went to 96 VDC, then began dropping after a moment.
Thanks!
It finally stabilized with 40 VDC on pin 1, -1 V on pin 2, 101 V on the supply.
Anyway, great breakthrough for me! Thanks so much!
I still don't know why I cant get more -V on the grid, the -1 VDC was obtained with the 37-100 mHz coil and the air cap all the way open.
Cleaning the old socket connections may help with that.
Again, thanks for your great advice!
                                                       Robert
Heathkit GD-1B - by vecher - 12-31-2018, 06:37 PM
RE: Heathkit GD-1B - by gregb - 12-31-2018, 06:44 PM
RE: Heathkit GD-1B - by Radioroslyn - 12-31-2018, 06:58 PM
RE: Heathkit GD-1B - by vecher - 12-31-2018, 06:59 PM
RE: Heathkit GD-1B - by vecher - 12-31-2018, 07:02 PM
RE: Heathkit GD-1B - by Steve Davis - 12-31-2018, 07:56 PM
RE: Heathkit GD-1B - by Steve Davis - 12-31-2018, 07:57 PM
RE: Heathkit GD-1B - by Radioroslyn - 12-31-2018, 08:03 PM
RE: Heathkit GD-1B - by vecher - 01-01-2019, 10:09 PM
RE: Heathkit GD-1B - by Chas - 01-01-2019, 11:17 PM
RE: Heathkit GD-1B - by vecher - 01-02-2019, 12:11 AM
RE: Heathkit GD-1B - by Radioroslyn - 01-03-2019, 11:28 AM
RE: Heathkit GD-1B - by vecher - 01-09-2019, 01:46 AM
RE: Heathkit GD-1B - by Surfur - 01-17-2019, 01:46 AM
RE: Heathkit GD-1B - by Radioroslyn - 01-17-2019, 10:52 AM
RE: Heathkit GD-1B - by Surfur - 01-17-2019, 01:24 PM
RE: Heathkit GD-1B - by vecher - 01-19-2019, 12:14 AM
RE: Heathkit GD-1B - by vecher - 01-19-2019, 09:39 PM
RE: Heathkit GD-1B - by Surfur - 01-20-2019, 02:58 AM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 11:10 AM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 04:56 PM
RE: Heathkit GD-1B - by KCMike - 01-20-2019, 05:53 PM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 08:29 PM
RE: Heathkit GD-1B - by vecher - 01-21-2019, 12:04 AM
RE: Heathkit GD-1B - by vecher - 02-15-2019, 09:17 PM
RE: Heathkit GD-1B - by EdHolland - 02-15-2019, 09:39 PM
RE: Heathkit GD-1B - by Surfur - 03-12-2019, 10:12 PM
RE: Heathkit GD-1B - by EdHolland - 03-12-2019, 11:57 PM
RE: Heathkit GD-1B - by vecher - 03-13-2019, 03:00 PM
