Zenith racetrack, what is the bracket for?
Gee I hope I have not posted this before, I looked and cannot find it. Anyway. On a Zenith racetrack oval bakelite, there is a rectangular slot at the top back. There is a rectangular piece held on there with two screws. Some sort of bracket or cover device, but for what? I thought it might be to allow some sort of adapter for wall mounting, or some accessory. It has no visible purpose, and I cannot believe they would go to the expense of adding the parts for no reason. Extra production costs, but pennies times many thousands. Icon_confused:
Zenith racetrack, what is the bracket for? - by tom2 - 11-28-2010, 10:19 PM
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
