Zenith 5G500
Yes inside without taking it apart!!! Spray WD-40 around the shaft and around the connecters might have to do this once a day for several days keep working the control back and forth. Learned that trick from the guy who had the old army generator I talked about in the what you fixed today thread. Jack was old school EE and signal corp from WW2. Him and his friend J.M. could just about make anything work.
Zenith 5G500 - by morzh - 01-26-2019, 09:18 PM
RE: Zenith 5G500 - by morzh - 01-27-2019, 09:10 PM
RE: Zenith 5G500 - by Eliot Ness - 01-28-2019, 10:33 AM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 12:05 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 12:46 PM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 02:45 PM
RE: Zenith 5G500 - by David - 01-28-2019, 02:58 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 05:53 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 12:14 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 02:47 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 03:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 06:14 PM
RE: Zenith 5G500 - by jcassity - 02-01-2019, 06:53 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 09:30 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 10:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 11:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 11:57 PM
RE: Zenith 5G500 - by morzh - 02-05-2019, 12:10 AM
RE: Zenith 5G500 - by morzh - 02-10-2019, 09:29 PM
RE: Zenith 5G500 - by David - 02-10-2019, 09:55 PM
RE: Zenith 5G500 - by morzh - 02-10-2019, 11:21 PM
RE: Zenith 5G500 - by EdHolland - 02-11-2019, 05:26 PM
RE: Zenith 5G500 - by morzh - 02-11-2019, 05:37 PM
RE: Zenith 5G500 - by David - 02-12-2019, 01:28 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 10:26 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 10:59 PM
RE: Zenith 5G500 - by morzh - 02-16-2019, 05:20 PM
RE: Zenith 5G500 - by morzh - 02-17-2019, 03:26 PM
RE: Zenith 5G500 - by Arran - 02-17-2019, 10:40 PM
RE: Zenith 5G500 - by morzh - 02-20-2019, 10:07 AM
RE: Zenith 5G500 - by WyTex - 02-20-2019, 10:48 AM
RE: Zenith 5G500 - by morzh - 02-20-2019, 01:11 PM
RE: Zenith 5G500 - by morzh - 02-23-2019, 01:39 PM
RE: Zenith 5G500 - by Eliot Ness - 02-24-2019, 12:56 PM
RE: Zenith 5G500 - by morzh - 02-24-2019, 10:22 PM
RE: Zenith 5G500 - by morzh - 02-25-2019, 10:22 PM
RE: Zenith 5G500 - by Arran - 02-26-2019, 02:58 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:47 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:52 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 10:10 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 08:40 AM
RE: Zenith 5G500 - by WyTex - 02-27-2019, 09:53 AM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 09:59 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 12:26 PM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 04:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-28-2019, 03:52 PM
RE: Zenith 5G500 - by morzh - 02-28-2019, 05:23 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:36 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:41 PM
RE: Zenith 5G500 - by morzh - 03-01-2019, 12:51 PM
RE: Zenith 5G500 - by Arran - 03-02-2019, 02:39 AM
RE: Zenith 5G500 - by morzh - 03-02-2019, 08:44 PM
RE: Zenith 5G500 - by morzh - 03-03-2019, 05:02 PM
RE: Zenith 5G500 - by Phlogiston - 03-03-2019, 08:35 PM
RE: Zenith 5G500 - by morzh - 03-04-2019, 09:38 AM
RE: Zenith 5G500 - by morzh - 03-04-2019, 10:08 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 11:16 AM
RE: Zenith 5G500 - by morzh - 03-05-2019, 02:13 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 02:39 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 06:47 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 08:09 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:56 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:57 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 08:43 AM
RE: Zenith 5G500 - by Eliot Ness - 03-06-2019, 03:27 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 04:12 PM
RE: Zenith 5G500 - by EdHolland - 03-06-2019, 05:01 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 11:45 PM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 10:02 AM
RE: Zenith 5G500 - by morzh - 03-07-2019, 10:59 AM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 01:57 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:28 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:30 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 12:03 PM
RE: Zenith 5G500 - by OldRestorer - 03-09-2019, 09:52 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 11:01 PM
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
