Restored Philco 46-420 code 121 has slight low pitch hum.
OK I want to thank everyone for some great troubleshooting and suggestions.
Morzh enlightened me on the use of a tracer, some possible cap replacements and a temp PM speaker test and Radioroslyn gave me some direction with the temp electrolytic on 50L6 and the fact that I might be staring at an output trans issue.
I decided that the almost pristine "totem pole" speaker - coil - trans assembly was something I wanted to do so I did it.
The result seems to have helped a decent amount. You need to be close to the speaker to hear a light low pitch hum and when tuned to a station it is only evident when there are pauses in conversation and from a distance across the room you cannot hear any hum.
I think if I do anything else it would be revisiting solder points for blob drips that I can solder suck and maybe swap in a different cap or two.
At this point I think I'm satisfied (again, hey for $10.50...).
Thanks everyone.
Over and out.
RE: Restored Philco 46-420 code 121 has slight low pitch hum. - by terrylett - 03-19-2019, 11:14 PM
