Fisher 500C restoration
#67
Ed
I looked at a 500-C service manual (S/N 30001 - 49999, not knowing the S/N of your unit) and I found the instructions as confusing as you did.
So I looked at the procedure for the 500-B. The procedure appears to be the same, but the text is worded in a more understandable manner:
Quote:Hot lead of DC VTVM to Test Point 4. Ground lead of DC VTVM to junction of two series connected resistors (47K), wired between Test Point 3 and ground (emphasis mine).
Adjust: Z5 top
Indication: Zero indication on zero center dial.
So it appears that you add two 47K resistors in series between Test Point 3 and ground, just long enough to make that adjustment, then remove the 47K resistors.
Fisher 500C restoration - by EdHolland - 02-03-2019, 06:03 PM
RE: Fisher 500C restoration - by morzh - 02-03-2019, 06:11 PM
RE: Fisher 500C restoration - by Ron Ramirez - 02-03-2019, 06:50 PM
RE: Fisher 500C restoration - by EdHolland - 02-03-2019, 07:25 PM
RE: Fisher 500C restoration - by Ron Ramirez - 02-03-2019, 07:58 PM
RE: Fisher 500C restoration - by EdHolland - 02-04-2019, 09:07 PM
RE: Fisher 500C restoration - by EdHolland - 02-20-2019, 05:07 PM
RE: Fisher 500C restoration - by KCMike - 02-20-2019, 06:03 PM
RE: Fisher 500C restoration - by Ron Ramirez - 02-20-2019, 11:11 PM
RE: Fisher 500C restoration - by EdHolland - 02-21-2019, 03:10 PM
RE: Fisher 500C restoration - by EdHolland - 02-25-2019, 06:46 PM
RE: Fisher 500C restoration - by EdHolland - 03-01-2019, 05:02 PM
RE: Fisher 500C restoration - by EdHolland - 03-15-2019, 08:22 PM
RE: Fisher 500C restoration - by TV MAN - 03-16-2019, 09:20 AM
RE: Fisher 500C restoration - by EdHolland - 03-17-2019, 08:35 PM
RE: Fisher 500C restoration - by EdHolland - 03-18-2019, 10:29 PM
RE: Fisher 500C restoration - by EdHolland - 03-20-2019, 09:27 PM
RE: Fisher 500C restoration - by EdHolland - 03-21-2019, 03:23 PM
RE: Fisher 500C restoration - by EdHolland - 03-22-2019, 10:44 PM
RE: Fisher 500C restoration - by EdHolland - 03-22-2019, 11:12 PM
RE: Fisher 500C restoration - by morzh - 03-23-2019, 11:45 AM
RE: Fisher 500C restoration - by morzh - 03-23-2019, 03:40 PM
RE: Fisher 500C restoration - by EdHolland - 03-23-2019, 08:23 PM
RE: Fisher 500C restoration - by morzh - 03-23-2019, 08:29 PM
RE: Fisher 500C restoration - by Ron Ramirez - 03-23-2019, 10:20 PM
RE: Fisher 500C restoration - by EdHolland - 03-23-2019, 10:22 PM
RE: Fisher 500C restoration - by EdHolland - 03-23-2019, 11:09 PM
RE: Fisher 500C restoration - by morzh - 03-24-2019, 10:45 AM
RE: Fisher 500C restoration - by Phlogiston - 03-24-2019, 01:11 PM
RE: Fisher 500C restoration - by EdHolland - 03-24-2019, 02:15 PM
RE: Fisher 500C restoration - by morzh - 03-24-2019, 02:18 PM
RE: Fisher 500C restoration - by EdHolland - 03-24-2019, 10:56 PM
RE: Fisher 500C restoration - by morzh - 03-25-2019, 09:07 AM
RE: Fisher 500C restoration - by EdHolland - 03-27-2019, 01:20 PM
RE: Fisher 500C restoration - by EdHolland - 03-30-2019, 07:49 PM
RE: Fisher 500C restoration - by morzh - 03-31-2019, 10:51 AM
RE: Fisher 500C restoration - by EdHolland - 03-31-2019, 07:31 PM
RE: Fisher 500C restoration - by EdHolland - 03-31-2019, 09:59 PM
RE: Fisher 500C restoration - by morzh - 03-31-2019, 10:23 PM
RE: Fisher 500C restoration - by EdHolland - 03-31-2019, 10:55 PM
RE: Fisher 500C restoration - by morzh - 04-01-2019, 08:32 AM
RE: Fisher 500C restoration - by TV MAN - 04-02-2019, 11:38 AM
RE: Fisher 500C restoration - by Ron Ramirez - 04-02-2019, 12:30 PM
RE: Fisher 500C restoration - by EdHolland - 04-07-2019, 10:10 PM
RE: Fisher 500C restoration - by EdHolland - 04-14-2019, 10:04 PM
RE: Fisher 500C restoration - by Phlogiston - 04-15-2019, 11:41 AM
RE: Fisher 500C restoration - by EdHolland - 04-15-2019, 02:51 PM
RE: Fisher 500C restoration - by Phlogiston - 04-15-2019, 06:23 PM
RE: Fisher 500C restoration - by EdHolland - 04-21-2019, 02:36 AM
RE: Fisher 500C restoration - by EdHolland - 04-21-2019, 02:45 PM
RE: Fisher 500C restoration - by EdHolland - 04-21-2019, 09:44 PM
RE: Fisher 500C restoration - by EdHolland - 04-23-2019, 12:51 PM
RE: Fisher 500C restoration - by EdHolland - 04-25-2019, 03:57 PM
RE: Fisher 500C restoration - by EdHolland - 04-30-2019, 08:05 PM
RE: Fisher 500C restoration - by EdHolland - 05-05-2019, 05:35 PM
RE: Fisher 500C restoration - by EdHolland - 05-12-2019, 03:35 PM
RE: Fisher 500C restoration - by Ron Ramirez - 05-12-2019, 04:26 PM
RE: Fisher 500C restoration - by EdHolland - 05-12-2019, 07:15 PM
RE: Fisher 500C restoration - by EdHolland - 05-19-2019, 09:07 PM
RE: Fisher 500C restoration - by morzh - 05-20-2019, 02:37 PM
RE: Fisher 500C restoration - by EdHolland - 05-20-2019, 06:05 PM
RE: Fisher 500C restoration - by Ron Ramirez - 05-20-2019, 08:57 PM
RE: Fisher 500C restoration - by morzh - 05-21-2019, 12:22 PM
RE: Fisher 500C restoration - by EdHolland - 05-23-2019, 12:07 AM
RE: Fisher 500C restoration - by EdHolland - 05-23-2019, 01:30 AM
RE: Fisher 500C restoration - by EdHolland - 05-24-2019, 03:28 PM
RE: Fisher 500C restoration - by Ron Ramirez - 05-25-2019, 06:45 PM
RE: Fisher 500C restoration - by EdHolland - 05-25-2019, 09:44 PM
RE: Fisher 500C restoration - by EdHolland - 05-29-2019, 11:10 AM
RE: Fisher 500C restoration - by EdHolland - 05-30-2019, 10:42 AM
RE: Fisher 500C restoration - by EdHolland - 06-01-2019, 11:49 PM
RE: Fisher 500C restoration - by Ron Ramirez - 06-02-2019, 08:07 AM
RE: Fisher 500C restoration - by EdHolland - 06-02-2019, 11:09 PM
RE: Fisher 500C restoration - by EdHolland - 06-08-2019, 11:47 PM
RE: Fisher 500C restoration - by EdHolland - 06-10-2019, 04:04 PM
RE: Fisher 500C restoration - by EdHolland - 07-10-2019, 08:52 PM
RE: Fisher 500C restoration - by Ron Ramirez - 07-12-2019, 10:43 PM
RE: Fisher 500C restoration - by EdHolland - 07-14-2019, 11:02 PM
RE: Fisher 500C restoration - by EdHolland - 07-20-2019, 11:18 PM
RE: Fisher 500C restoration - by EdHolland - 07-24-2019, 01:51 AM
RE: Fisher 500C restoration - by gregb - 07-24-2019, 07:18 AM
RE: Fisher 500C restoration - by EdHolland - 07-24-2019, 05:48 PM
RE: Fisher 500C restoration - by rfeenstra - 07-24-2019, 06:24 PM
RE: Fisher 500C restoration - by EdHolland - 07-28-2019, 12:00 AM
RE: Fisher 500C restoration - by EdHolland - 07-28-2019, 11:08 PM
RE: Fisher 500C restoration - by morzh - 07-29-2019, 07:55 AM
RE: Fisher 500C restoration - by EdHolland - 07-31-2019, 11:43 AM
RE: Fisher 500C restoration - by Phlogiston - 07-31-2019, 12:21 PM
RE: Fisher 500C restoration - by EdHolland - 07-31-2019, 08:46 PM
RE: Fisher 500C restoration - by Joeztech - 08-02-2019, 07:47 AM
RE: Fisher 500C restoration - by Joeztech - 08-02-2019, 09:58 AM
RE: Fisher 500C restoration - by EdHolland - 08-04-2019, 04:31 PM
RE: Fisher 500C restoration - by Phlogiston - 08-05-2019, 12:01 AM
RE: Fisher 500C restoration - by EdHolland - 08-05-2019, 05:01 AM
RE: Fisher 500C restoration - by EdHolland - 08-26-2019, 12:09 AM
RE: Fisher 500C restoration - by doc_zap - 09-10-2019, 11:53 PM
RE: Fisher 500C restoration - by EdHolland - 09-11-2019, 12:24 PM
