Model 71, filter condenser bank voltage
Working on a model 71.  My questions is about part # 21, the filter condenser bank (05324).  My old Philco parts list indicates the metal case capacitors (05324) as having a 1200 volt “test voltage.”  I know normally, use same voltage or higher rating caps but as this is “test voltage”, would a lower voltage work safely?  Bottom line….what would you recommend?  I’ve got plenty of 600 volt orange drops….not so much, caps in the 1.2kv range. Ha
Thanks!
Hoke
Model 71, filter condenser bank voltage - by hokep61 - 06-20-2019, 04:11 PM
