38-7 dial switch stuck & possible bad field coil
> I'm assuming the humbucking coil wouldn't be needed?
Yes because it works off of the magnetizum provided be the field coil and your not using one.
> It calls for 120 and 130ohms, I was getting 185 and 194.
As long as the each of the windings (from center to center) are fairly close in resistance I wouldn't loose any sleep over it. If it were 20 ohms or more it may suspect.
Now I think I've got it!
RE: 38-7 dial switch stuck & possible bad field coil - by Radioroslyn - 07-05-2019, 12:32 AM
