Problems with 116b after chassis cleaning
Hmmmm Doesn't sound good. I would disconnect the shadow graph and check the resistance of the coil. It may be open (not good) You could add a jumper across the the graph and see if that helps the performance. Check #47 for shorts and the #76 tube for shorts.
Sparking form the bandswitch is bad! You will need to take a close look at it and find out whats arcing. Clean well make sure that there aren't any carbon traces. If you don't you can burn up the phenolic part of the switch then the terminals will come apart.Sometimes you can use a bit of epoxy to repair the wafer. Double check any parts of the switch that has B+ on it. Those would be the ones connected to the plate circuits of the RF amp and the LO.
Good luck
Now I think I've got it!
Re: Problems with 116b after chassis cleaning - by 7estatdef - 12-11-2010, 04:41 PM
There are currently 2428 online users. [Complete List]
» 1 Member(s) | 2427 Guest(s)
