model 38-10 no reception after recap
Not sure which connections we are talking about but the coil you can gently scrape the wires at the solder connection and re solder. If it's the tube socket you can use a pair of needle nose pliers and gently pinch the connector on the socket w/o the tube in place. Be careful the metal can be weak and fold easily then your looking at a new socket.
To improve the performance you'll need a signal generator to adjust the IF amplifier and other stages of your set. Something simple is fine just need to verify it's accuracy.
Now I think I've got it!
model 38-10 no reception after recap - by pkingco - 02-22-2020, 04:47 PM
RE: model 38-10 no reception after recap - by Radioroslyn - 02-23-2020, 01:03 PM
There are currently 1908 online users. [Complete List]
» 1 Member(s) | 1907 Guest(s)
